Stihl Ms 260 spark plug help
woody367
OPE Member
11:13 PM
NY
New to the site with my first question.I have a stihl ms260 chainsaw that the spark plug threads looks slightly damaged. I was wondering if somebody can tell me the cap size for that spark plug to try chasing it or if there's a kit to repair the threads. Also what's the spark plug number in NGK for that. I also have a 026 that needs a new plug. Is there a site to go to to find the service manuals on the source? Thank you in advance.
SimonHS
4:13 AM
Yorkshire, England
NGK BPMR7A plug for both saws. The thread size is M14 x 1.25.
You can get a thread chaser that size. If it doesn't make the thread better then you will need a thread insert repair kit. Time-Sert or Keen-Sert or similar are best. The thread reach on the plug is 9.5mm so you need short inserts to match.
woody367
OPE Member
11:13 PM
NY
Thank you, I think my tap and die set might have taps for spark plugs. Where might I find the service repair manuals in PDF in case I need them. I was given theses saw and will try seeing what the may need.
Bryan Newton
10:13 PM
Glencoe, Oklahoma
There is a post on here called stihl workshop manuals you should beable to fine it there
ray benson
10:13 PM
nw indiana
Check your inbox for the 026 and 260 ipls and service manuals.
xatel75595
New OPE Member
11:13 PM
GA
Perfect
