fxrtharley
New OPE Member
- 12:47 PM
- Jul 8, 2024
- madison wisconsin
Hi, my chainsaw has been dependable but now went to use it and it will not start.
The saw is probably 6 years old used a few times a year and I do not use ethanol gas. I am guessing it is now fuel related since I did try to prime and start but the plug was dry: I did not see any cracks in the fuel line and the tank filter looks clean. I know you are not supposed to use starting fluid but I did throw a bit in and put the plug back in but no pop.
I know I have spark but is there a way to add fuel to make sure it will pop and is it worth trying to clean the carb or just find a new one if the carb is suspected? I have tried to rebuild carbs with no success but maybe just a cleaning with aerosol carb cleaner has been known to be all it needs.
Any suggestions are appreciated, I know it is an easy fix, just need to find the culprit before I spend $ on a shop. thanks
