Stihl FS-85 fully adjustable carb.
bwalker
2:32 AM
Montana
Does anyone know the correct Walbro carb for a FS-85? Rather not go with a Zama.
Carb on it is a non adjustable carb and it needs to go.
leadfarmer
Hot Rod !!!
2:32 AM
S Central PA
got this yesterday, it is fully adjustable. Didn't look which it was but my fs 80 runs good now
Fishnuts2
1:32 AM
SE MN
I've used 2 of the clone carbs that I got from Russo Power on both my FS85s. Fully adjustable and run great right out of the box $15.
bwalker
2:32 AM
Montana
Walbro number for the stihl part?
leadfarmer
Hot Rod !!!
2:32 AM
S Central PA
I guess I should have posted on here first....I could have had 2 1/2 carbs [emoji35]
junkman
Crush it
11:32 PM
pacific northwest
the ones listed for the fs45 and fs55 are identacle when i set them side by side ,i have two 15 dollar Chinese ones in use ,and they are working fine ,i did get 2 duds though that would not tune in .
Stihlbro
2:32 AM
Virginia
I've put a boat load of the fs 45/55 Zama carbs on the fs80/85's. They work good, and for the price it's hard to beat.
When I was looking for the walbro the wt264 is actually off a older fs 75. They work good too.
$60 dollar walbro or a $30 Zama?
junkman
Crush it
11:32 PM
pacific northwest
The one I have is a zama Ben. I looked at 2 weefeaters and a hedge trimmer, all had zama, I will check the weedeatets at work when get in see if walbroDSC_0005.JPG DSC_0006.JPG DSC_0007.JPG DSC_0008.JPG
bwalker
2:32 AM
Montana
I have had really poor luck with Zama carbs. I'd rather pay double and not have to worry about it. YMMV.
junkman
Crush it
11:32 PM
pacific northwest
Call me crazy but this 026 pro carb looks close enough to fit a weedeater if swap the throttle linkage and top and bottom carb covers ,look at the size difference on the filter side .jug side is a little bigger ,looks like the throttle shaft will swap ,026 is a walbro ,one with bulb is zama weedeater carbs 002.JPG weedeater carbs 003.JPG weedeater carbs 004.JPG weedeater carbs 005.JPG weedeater carbs 006.JPG
Fish
2:32 AM
Manton Ky.
You could say that about %75 of the carbs out there.
