Stihl BT 131 Z with drill chuck
NPKenny
6:00 PM
Lehi, AZ
I found a Stihl BT 131 for sale locally, in great shape. I want to use it as a auger, but it has a permant drill chuck installed. All of the IPL’s I have access to indicate the BT 131 comes with a splined shaft directly out of the gear box. Stihl pictures indicate that the common drill chuck attachment uses a splined adapter with retaining pin.
What does it take to convert this particular auger back to an earth auger?
Pictures might be huge as I’m posting from my iPad.
Thank you!
upload_2018-8-9_13-43-57.jpeg upload_2018-8-9_13-44-57.jpeg upload_2018-8-9_13-45-38.jpeg upload_2018-8-9_13-46-47.jpeg
NPKenny
6:00 PM
Lehi, AZ
Bringing this to the top. I don’t know a better place to post this. Looking for one of the Stihl experts to jump in. Thank you!
CR888
11:00 AM
What happens when you open the chuck right up, is there a left hand thread screw inside that can be removed so the chuck can be taken off? A Stihl tech will hopefully chime in, but I'd remove the chuck like you would a normal drill. Just remember LH threads are normally used on retaining screw.
nohoff
professional flusher
3:00 AM
Germany
the IPL shows only the drill chuck secured with a pin.
NPKenny
6:00 PM
Lehi, AZ
I am looking to buy the auger from a private party. I won’t be able to remove the chuck. I was thinking it would be a smooth shaft with a retaining screw.
This appears to be an anomaly. All IPL’s I’ve been able to find show the pin and coupler.
nohoff
3:00 AM
Germany
The shaft costs about 35 Euros in Germany + some gaskets this would end up about.
But you have to remove the chuck to open the gear case.
NPKenny
6:00 PM
Lehi, AZ
Thank you! I think Am going to pick it up.
Edlldoit
New OPE Member
9:00 PM
Florida
Did you ever figure out how to convert it back I have the same drill and want to convert it back to an earth auger what all do I need?
