FOUND IT Stihl 441c cases and crank
redline4
I'm huge in Japan
8:49 PM
Rosholt Wisconsin
Looking for a matched set of Stihll 441c cases and a good crankshaft.
Cases don't need to be cosmetically perfect. Missing some paint, scratches are fine.
Needs to be from an Mtronic saw though, regular carb saws have a different flywheel side case.
Good crankshaft needed too.
farminkarman
I like the red & black ones
8:49 PM
Neenah Wisconsin
That doesn’t sound good :(
lehman live edge slab
Live Action
8:49 PM
Mn
I will see what I have for you in the parts box, I have few month old 441 that ate a ring so needs a top end that I was going to build but maybe will let it go if the 3 parts saws I have don’t work. And what did you do thought it was running well after the recalibration?
redline4
I'm huge in Japan
8:49 PM
Rosholt Wisconsin
I'm pretty sure I have all parts I need coming.
It was running good.
Good running doesn't mean bearing won't fail though. It happens.
Live Action
8:49 PM
Mn
Let me know I’ll look at the cranks and cases I have anyway just in case
