mattbred
Active OPE Member
- 2:27 AM
- Aug 19, 2020
- BC, Canada
I bought my 261 mtronic new 3 years ago. It worked really well for about 2 years but has now developed an issue.
I always use ethanol free premium fuel with Stihl oil/stabiliser mix. I've replaced the spark plug, fuel solenoid (with white one), and fuel filter and cleaned the air filter.
Here is the situation. The saw starts and runs great cold. I let it warm up for a minute and can cut a bunch of rounds. I can shut it off and start it within a minute no problem.
If I let it sit for about 5-10 minutes and try to start it again, it will not start in any position. It will ignite here and there for a couple RPM and then die. If I hold it WOT and give it some pulls, then choke it, I might get lucky and get it running. If I give it ANY throttle it immediately bogs down and dies. I have to go through this routine for about 15 minutes to get it working properly again. Meanwhile, I have to be very delicate with the throttle or it bogs and dies.
I did notice one thing the last time it happened. I opened the fuel cap and gas sprayed out, like it was under a ton of pressure. There were also lots of little bubbles rising up. It would not start with the gas cap off.
Any ideas?
Any ideas?
