Stihl 261c coil
trucky
Active OPE Member
11:33 PM
NNY
Anyone know if any other coils will fit a ms261c ? Don't really want to spend the money on oem. I can't seem to find an aftermarket one either. Thanks.
trucky
Active OPE Member
11:33 PM
NNY
I just saw an old post on AS where someone used a 361 coil. I've got a 361 so I guess I'll try the coil off that see if it works.
trucky
Active OPE Member
11:33 PM
NNY
Finally got around to putting the 361 coil (1135 400 1300) on the 261. It is the same size so the fit was perfect. Started right up and ran good. I am just waiting for a new clutch drum to get here so I can get it in some wood. Still not sure what the difference Is between the coils other than the part number.
backhoelover
SERVICE MANUAL MASTER
11:33 PM
lincolnton nc
just check rpm its the same on both engines. should be good to go
trucky
Active OPE Member
11:33 PM
NNY
I have not checked yet. As soon as I get the new drum and sprocket I'll check rpm's and post my findings.
backhoelover
11:33 PM
lincolnton nc
no worries both saw have the same max rpm so the rev limits will be the same
trucky
Active OPE Member
11:33 PM
NNY
Got the saw on the tach today and every things good. 2800 rpms on idle and 13800 rpms.
skidooguy
Genuine smartass
9:33 PM
Wyoming
Glad to hear that it worked for you. That is handy info to remember for all that read this my friend.
trucky
Active OPE Member
11:33 PM
NNY
Glad I could give back just a little. I have learned a wealth of knowledge here.
11:33 PM
Now get it ported and see it turn 15800 rpms. lol
