Stihl 200 crank play?
2000ssm6
12:32 AM
NC
My dad straight gassed our rear handle 200. While taking it down, I checked the side to side play on the crank, came up with .012-.013". Is that excessive? No vertical play at all, wrist and main bearings feel good but haven't split cases.
@Mastermind @jacob j. @Lone Wolf
Thanks
Ketchup
Epoxy member
10:32 PM
Colorado
Always hard to know without seeing it but that sounds normal. I’ve never seen a 200 that didn’t have side to side slop both in the crank bearings and the rod bearings.
12:32 AM
First of all a disclaimer .I've never seen an 020 AV ,rear handle so I had to look at the IPL .From that it uses grooved ball bearing main bearings .The 020T /MS 200T used 8 roller ,roller bearings .Those will develop slop after a while where as it would take a lot more run time to wear out a ball bearing . Saying that 12-13 thou is not much wiggle IMO . The side slop that some 020T's develop in effect wears out the seals then it cooks the piston if not addressed .
