mikerudder
- 5:20 PM
- Jan 2, 2017
- Langley, BC Canada
Have a flat top short case 066 on the bench and need some assistance.
It has the dual key flywheel (PN 1122 400 1216)
Has the 1311 Coil on it
I am not getting spark - which keyway is used with the 1311 coil?
I'm starting to think the coil has gone on it, hasn't been run in a couple years.
It does have a generator and heated handle/carb, but not a heated handle bar
What is my best option for replacing the coil?
From what I have read I can either go with the 1311 or a 1300?
Or could it be the flywheel as well?
I am guessing I can't just change the flywheel and coil with with one that I have, since its an arctic model? Or does that matter?
