In the pic above..where the yellow line is, I've drilled a 1\16 hole into the plastic, and inserted a 1\16 dia pin into the hole. The pin then gives the fulcrum more upward lift.. Works perfect. And the pin does not wear out like the plastic at the bottom of the slot. You would drill about in the center of the yellow line so the hole would come through in the bottom of the slot that lifts the fulcrum, continue drilling almost all the way through after entering and exiting the slot, but not entirely through the whole handle, leaving a blind hole that you can drop\ push the pin into. I then take a soldering iron and melt the hole covering the pin so it won't ever budge. Takes five min max and works great.
