FarNorth
Active OPE Member
- 7:33 PM
- Aug 25, 2024
- Minnesota
Good evening guys, pulled my 032 AV out the other day and while cutting I blew the rear plug out of the back of the bar oil pump, we'll shoot. ok got that fixed and started it and got it running everything was working we'll for about 5 min, then started boging and shut down. can get it to pop off and fire a few times but won't run. pulled the plug and it's really wet, maybe flooding out? I am so stumped with this. I have since cleaned the carb ( I did not install a new kit just clean), checked spark by grounding out plug on PC, looks ok. checked compression cold, right at 160 psi. pressure and vacuum tested through impulse line and help 7 psi. pressure and vacuum tested the inlet fuel line from filter and to carb end, check out good. is there anything I am missing? I'm usually pretty sharp with this stuff, but this one is kicking my butt.
Thanks everyone! Pat
