FergusonTO35
- 8:29 AM
- Jul 9, 2017
- Boonesborough, KY
Hey folks, working on an early 2000's Troy Bilt V809 garden tractor for my father in law. Has varidrive dual range transaxle with 22hp B&S I/C twin. When you try to start it, the solenoid doesn't do anything. Power is good everywhere, however I find that there is about a 2 volt drop between the ignition switch and the small terminal on the solenoid. Battery is fully charged and tested good. I would think that 10+ volts would still be good enough to close the solenoid, but I could be wrong. Ground to the terminal is clean and good also.
Any ideas here? I'm thinking that the wire between the ignition switch and solenoid has some resistance caused by dirt/oil/corrosion/whatever and just needs to be replaced. Or is there something else I should check?
