Started Asian 440 BB #4 Today
MG porting
4:09 AM
Wa
Well, I got news of my first saw failure yesterday - an Asian 440 Big Bore someone took off my hands.
Got the saw back this morning and ripped it down. The lower ring hung up on the bottom of the Exhaust port, which I did not widen, (I only widened the top)and I made sure it was beveled (both top and bottom). I also noticed that the lower rod bearing was starting to go, and I'm wondering if that caused the ring to hang up.
Another similar one I built for a Tree Pro had a lot more hours on it w/o any problems. This guy (with the failure) loved the saw, and always ran 40:1, but the 2 cycle oil he uses is not as good as the AMSOIL Saber I use. Luckily, I had another nearly identical saw I sent his way, so he will not be without. It is by far his favorite firewood saw. He has some decent sized hardwoods on his property, and says this saw goes through it twice as fast as his other saws.
So I have the following questions (comments welcome):
Is it likely that the lower rod bearing starting to fail resulted in the ring hanging up???
Did I get a bad crank, or are they all crap waiting to fail???
Will better oil keep them healthier a lot longer???
I'm hoping that some folks with time on these things will respond.
Thanks, Mustang Mike
Better oil and more of it the bearings aren't ass good.... But I'm sure you ported the cylinder to this is why I run the clones I've built 32:1 they need that extra oil.:beer-toast1:
Absolution
7:09 AM
WV/NC
One of these days if I have to rebuild my saw I'm going to hunt down a set of ceramic bearings for crank and do a OEM for bottom rod bearing.
7:09 AM
I spent a lot of money to put ceramic bearings in a bike, and did not notice any difference at all. In addition, they don't like vibrations (ceramic is very hard, but brittle) so I would not put them in anything other than a race saw.
If you can find/afford any OEM crank, I'm sure they are better. Wish you could just change the bottom bearing. However, I think the 660 cranks have been holding up well.
BuckthornBonnie
7:09 AM
Penn Yan, NY
I’ve had them in my cart a few times, but never pulled the trigger to try one.
AM cranks, Huztl cylinders for pro saws, and any other piston besides OEM and Meteor scare me (have tried a few of those other items).
smokey7
7:09 AM
Detroit
I have several aftermarket cranks in saws for homeowners and firewood guys. Havnt seen any failures other then I've had so e rejects from being out or true/phase wrong dimensions/diameter missing key slots.
smokey7
7:09 AM
Detroit
I would bet that poring the oil to them as in 32:1 or more and of a good quality they will likely last a while longer. I'm betting that the wear surfaces (pins/rollers/races) are not as hard or free from imperfections. So they just won't last as long as a pen crank regardless of amount of quality of oil.
7:09 AM
I have no delusions that the AM cranks/bearings are as good as OEM, yet I have seen some of them hold up pretty well in strong running ported saws.
I'm hoping this one was a defect, and that most of them hold up much longer if good oil and mix ratio are used.
The 660s definitely seem to be more robust than the 440s, but the 440 is such a more useful all around size saw, and a well ported BB kit can run pretty darn well.
MG porting
4:09 AM
Wa
Can't remember what post I was on when I was putting the big bore on my 660 clone and I'm not trying to side blind you MustangMike just wanted to show how well the crank holes up on the 660 with a mass amount of compression. IMG_20190611_095212.jpg IMG_20190611_095222.jpgthis thing is a bare to pull over.lol
MG porting
4:09 AM
Wa
Post away, the more info the better!
Now if I were to build a 440 to get that much compression eh I would have to go with a OEM crank I think the clone crank shaft is comfortable at 175psi to 180psi but I've never really tried to push one much further than that.
7:09 AM
Mike, I don’t believe that there is a straight answer to your question.
OEM cranks should live longer because of superior raw materials/machining/quality control.
That includes metallurgy and production costs, etc...
I’d go OEM or equivalent (meteor pistons) on all reciprocating components. There is a reason people pay 10x the amount for an OEM crank.
OEM internals are cheap insurance that something won’t go BOOM too quickly.
It always comes back to that old expression “you get what you pay for”. I think it’s gonna be rare to find more AM components than OEM holding up after a lot of usage.
The more saws you build, the more likely a failure. Just how it is. It’s not a good feeling when one fails, not one bit. It’s cheaper for the OEM to build a more reliable component than to deal with warranty claims, hence the evolution of the 044 from 10 to 12mm cranks.
7:09 AM
Good post Al. Now, if we could only get Meteor to make us some affordable cranks!!!
I was actually wondering if all the AM cranks are sourced from the same place, or if there are different manufacturers with different levels of performance.
I'll also try to put some time on some of these to see if some of them do hold up well. Hey, even OEM (especially used OEM) fail every now and then!
