Spark Plug Gap: NGK vs. STIHL
Merkava_4
5:27 PM
Clovis, California
I bought an NGK CMR4H. NGK says they recommend the gap to be .028". STIHL says it should be .020".
The actual gap I measured with a feeler leaf is .025". Can I leave it at .025" or should I squeeze is down to .020" ?
This is for my STIHL FS 91 R string trimmer which I consider to be a hero machine.
hacskaroly
2100 Fanclub Member
5:27 PM
Northern Idaho, Ehh
I typically gap all of my chainsaw spark plugs to .025. That is what I have my FS 91 R set at too.
Coupe
12:27 PM
New Zealand
This is what stihl recommend so think I would stick to that.
AI Overview
Using The Right Spark Plug For Your STIHL Tools | STIHL Blog
Stihl's recommended spark plug gap is 0.020 inches (0.5 mm) for most of their trimmers, blowers, and chainsaws, including the FS 91. A proper gap is crucial for combustion and preventing misfires. While 0.020" is the standard, larger engines may require a slightly larger gap, such as 0.025" (0.635 mm).
k to that.
lehman live edge slab
Live Action
7:27 PM
Mn
Cmr 4h? Thought all the stihls with small plug called for cmr6h which is cooler than the 4 you used. But maybe some do call out for the 4 instead.
