silvey 600
Straulina
Active OPE Member
1:26 AM
New Jersey
I have a new to me silvey 600 , my question is on the chain holder. it has a hand bolt to hold in place but there is no pins or a ledge to index it to same place. meaning if I take it off or rotate it 180 degrees I have to guess where it goes. I can set it up with a level but it would seem there should be some sort of shelf for it to sit on.
Thanks. Tom
1:26 AM
Straulina
Active OPE Member
1:26 AM
New Jersey
not a home right now but I can if needed . the vice can move horizontal, pivot either way, it seems it should sit on something. I leveled it and tightened the bolt that holds it and it grinds fine
srcarr52
1:26 AM
Iowa City
Why do you have to rotate it 180? It should have 2 chain stops on it for left and right side cutters and the motor can be run in reverse.
Straulina
Active OPE Member
1:26 AM
New Jersey
It has two drifferent size grooves on the chain vice . it looks like 050 0n one side and 063 on the other. im not talking about the top plate angle
Straulina
Active OPE Member
1:26 AM
New Jersey
if the vice is set a zero and I loosen the t bolt I can move the vice out of level
srcarr52
1:26 AM
Iowa City
Ok, I get what you want to do now.
Why don't you get it level where you like it and score a line under the chain vise so you can return it to the correct height and angle.
Straulina
Active OPE Member
1:26 AM
New Jersey
I have to leave I can reply later thanks in advance for any help
Straulina
Active OPE Member
1:26 AM
New Jersey
It has a small protrusion that the vice sits against . but you have to eyeball it . I checked with my digital angle guage and it is on but if there was a lip it would be easier
