Thesandman
- 10:32 AM
- Jan 22, 2021
- Mid michigan
I'm wanting to set up my echo to have a little fun with friends of mine. Sort of a wow moment for them. I want to port saw a little to highlight torque to run a 20" 8 pin rim clutch. I'm not sure about what all the chains are or if parts are available to do it. First off the only chain available around here that I can buy locally is Oregon full chisel and safety chain. Is the FC same as what the forum refers to as full comp? Is the 325 chain a 325 kerf vs 3/8s? Same teeth or smaller? Does it take a special Bar and clutch sprocket? Saw cuts at 8500 plus now in dead ash bar hurried. More like 9k. Thanks for your help.
