Sensitive member section only.
JohnnyBlade
JUST GONNA SEND IT
3:27 PM
Momence,IL
I don't like your tone. I'll have you know I moderate a Furby collectors message board, so I know how a forum is supposed to be ran.
:clap: He said Furby:cbiggrin:
I thought this was our safe space? I see nothing but volatility. Gonna have to report this to Worsham:D
Jason628
1:27 PM
Washington
I think anyone whoze gets offended by someone typing something on the interwebs oughta put the dagumm phone down and grow some testsickles.
Jason628
1:27 PM
Washington
Speaking of testsickles I Damm near froze mine off. I had my Chevy all apart and fixed her up with new seals and gaskets and water pump and whathaveyou... well the frigging thermostat (bought random cheap one on rockauto) is some bs "fail safe" thermostat that is supposed to protect the engine somehow by locking all the way open supposedly when it gets too hot which, sounds kinda good in theory but, the truck usually sits a little above 200 degrees on a warm day and the thermostat is a 195 degree thermostat. Had no idear about these fail safe things and just dropped it in. Well it stuck wide open and I couldn't figure out why the darn thing had no heat and the temp gauge wouldn't move after idling for an hour and then holding her at like 3k rpm for 5 minutes. Lesson learned don't ever buy motorad fail safe thermostats.... I went to buy a new one and the frigging parts guy is like would you like the fail safe thermostat for $10 more and I'm like f you!
redline4
I'm huge in Japan
3:27 PM
Rosholt Wisconsin
O.e.m. for thermostats only.
Unless it's discontinued from the manufacturer, it's one of the parts I will refuse to install aftermarket.
Duce
4:27 PM
Roscommon, MI
I prefer them. Rather have them fail open, over failing closed. Rather return home, then be stuck on roadside with overheated motor.
Jason628
1:27 PM
Washington
I get the idea behind it but, it was brand new and I let the truck idle for a while like I normally do and it stuck open. Might test it on the stove to see what temperature it locks open at... I've never come close to overheating with that engine and it's been in Arizona with 115 degree heat and running the ac.
redline4
I'm huge in Japan
3:27 PM
Rosholt Wisconsin
Depending on ambient temp and driving conditions, stuck open can result in overheating too.
It does not allow enough time for the coolant to "cool" in the radiator.
Duce
4:27 PM
Roscommon, MI
I will take that chance over running closed.
Jason628
1:27 PM
Washington
I stick to things that are simple to work on. If I was to buy a newer Chevrolet it would have an LS with a cable operated throttle. My newest vehicle is an 06 and I've been driving around with a cel forever. (Electric smog pump took a dump) I hate working on it....
Jason628
1:27 PM
Washington
My buddy has a 01 gmc 2500 with the 8.1 it is a bad mofo but, has throttle control issues. We have replaced the pedal position sensor, control module and tried a different throttle body and it will still randomly throw a code and go to reduced engine power. A new throttle body for it is $400. Currently he is driving around with his scan tool plugged in so he can clear the code and get it out of reduced power mode.
Jason628
1:27 PM
Washington
Driving around with a stuck open thermostat in cold weather is not fun. It now gets up to normal temperature and I have heat.
redline4
I'm huge in Japan
3:27 PM
Rosholt Wisconsin
Pretty good chance it's the wire terminals in the connector at the throttle body.
I should be able to get you a part number for a new connector with leads if you wanted.
I had an 02 with the 8.1
