Searching for Es Light bar weights
Backtroller
8:04 AM
Land of Badgers
When I inquired about a 24” rollomatic e, not es, It was not available anymore. I remember seeing them years ago.
leadfarmer
Hot Rod !!!
9:04 AM
S Central PA
Here u go buddy
jk14
9:04 AM
Glenside Pa.
I have been trying to find a real world weight of a Stihl es light 25” 3003 000 2231. 3/8 .050 84 bar. I have found 20” and 32” but I can’t find other weights. Anyone have a source?
I posted weights of 20,25,28 and 32 es-light weights on here somewhere around January 2017 but I can not find it. The search doesn't work worth a *s-word. Maybe you'll have better luck. I will be out in the shop later this afternoon and will weigh them again.
jk14
9:04 AM
Glenside Pa.
The bar only. Then I can make an apples to apples comparison. Thanks
Oh wait I found it.
http://opeforum.com/posts/312061/
20" e standard .325-.063 = 2lb. 6.3oz
20" ES light 3/8-.050 =2lb. 0.9oz.
25" ES =3lb. 10.7oz.
25" ES light =2lb. 9.6oz.
28" ES =3lb. 14.2oz
28" ES wide nose. =4lb. 1.7oz.
28" ES light. =2lb. 12.0oz.
32" ES light. =3lb. 5.2 oz.
00wyk
2:04 PM
Ireland
Thanks, I had found that and while he had the es light weights for the 20” 28” 32” and 36,” there is not any 24-25” es lights. Just standard ES in that 24-25 length.
Guide bars: Rollomatic ES Light, 3/8", 1,6 mm, 63 cm / 25"
30030002031 VS 2038 for the 28" bar.
30030002021 for the 20" light.
Whether you can get them stateside is another matter.
Slacker
Hunny Locust Skipchain Sparker
9:04 AM
Durham, Mebane NC
Tsumura makes one, if it helps.
I PM'd, texted and sent bat signals to our resident Tsumara seller asking about buying a 16". No response.
It is Tsumara PN 200FK4.
D025, 3/8, .50 for the 16"
The same in 18" is PN 201FK4
Matt Ellerbee
9:04 AM
Canton,Georgia
Correct. But the 16” is not light weight, the 18” is.
Redbull661
661 hoarder (BlueBallz)
8:04 AM
MN
- 24" tsumura redesigned 050 3/8 84dl = 2lbs 7 oz (so it dropped some weight)
- 24/25" Stihl es light 063 3/8 84dl = 2lbs 8.5oz
not exact apples to apples but I would guess
- 24" tsumura 063 would be approx 1-2oz more (because tsumura uses thicker bar on the 063s)
- 24/25" stihl in 050 would be approx 1oz more @ 2lbs 9.5 oz. (because stihl uses the same thickness bar on 063 or 050...so with 050 there would be more metal left in the bar)
at least on all the Tsumura husky and stihl mounts I sell. FV = regular weight bar. FK = light weight.
I had my distributor order 16 + 18" lights 050 3/8 stihl mt (200FK4, 201FK4 ) back in Nov. ..should be here sometime in may. Also
237FK4 32" 063 stihl light,
238FK4 36" 063 light,
244FK4 32" 050 3/8 light,
433FK4 husky .063 32" light,
434FK4 husky 063 36" light
Slacker
9:04 AM
Durham, Mebane NC
at least on all the husky and stihl mounts I sell. FV = regular weight bar. FK = light weight.
Please PM me when they show.
I'm in for a 3/8 .050 18" ES light.
