Cerberus
Cerberus the aardvark, not the hell-hound!!
- 12:17 AM
- Jan 20, 2020
- Florida (tampa area)
I don't know the history of this saw (will put all relevant specs below!), problem is that I got it, fixed it up, got it a bar&chain and a week later the chain wasn't moving smooth at all --- turned out the new chain's drive-links were getting chewed-up!!
Potential causes seem limited to:
1 - wrong bar/chain/sprocket setup, or
2 - sprocket/clutch assembly is out-of-place (which it DOES appear to be, although obviously this problem wouldn't be mutually-exclusive to problem #1!)
When I got the saw it had no bar/chain so I have nothing to go on BUT all advert materials online seem to say it's a 3/8"LP setup....
But the sprocket/clutch.....when I got this saw there was a ton of hair/fiber squeezed-into the crank/axle that the sprocket sits on (ie I was pulling hairs/fibers out-of the interface between that axle and where it enters the powerhead) Furthermore, see the lil washer in-between the powerhead and the sprocket? Thing just bounces all over, I mean literally I can slide it 1/4" back&forth in that space! My 1st thought is "it can't be that the sprocket isn't fully-seated, because the saw will seat it for you if it wasn't" but now I'm wondering because the drive-links *are* getting chewed-up on the outer side (sprocket-side) so makes sense this is simply an issue of the chain riding the very-edge of a chewed-up sprocket......would really like to push this machine til it dies though, so right now my best plan of attack is to simply remove the clutch/sprocket assembly & reinstall it in-hopes that it seats deeper, ANY advice here would be massively appreciated!!! In these pics the bar&chain are mounted properly *w/o* the side plate/body-panel that's usually over them I just mounted it w/o the body-panel to show what was what!
Specs:
Saw is a "Tanaka tcs33edtp"
Factory manual says for 12" and 14" setups it comes with Oregon 91PX's, a "VG045" for 12" and "VG052" for 14" (these chains seem to only be made for this saw, can't find info on them outside of Tanaka links)
The "offending" bar&chain combo I put on was a regular Oregon 16" 3/8"LP setup, *felt* like it was running perfect til it mangled my drive links!
16" Oregon setup:
Bar: 160SDEA041 (oddly, when googling this, I can find a variety of Oregon bars, so want to be clear my bar&chain came as a pre-packaged combo kit!)
Chain: S56
I guess it could be the chain(/bar) but the more I look at the sprocket the more I think "that sucker is 1/4" from fully-seated"...
Thanks a TON for any help on this, I know it's nothing impressive here but for me this saw was a many-weeks restoration of a "damaged beyond repair" unit so am very stoked to have had it in my arsenal and equally upset to remove it so soon due to shredding drive-links (FWIW I did just put a new chain on so I could do another session and see if it mangles them the same way, think I'm still hoping I just got a rock jammed-in there or some other manner of 1-time error!!!)
Specs:
16" Oregon setup:
Chain: S56
