Fruecrue
certified hand catcher
- 2:41 PM
- Jan 4, 2017
- Alden NY
Time to sell, shipping available or can deliver to Duane’s PA GTG.
This is gonna start unorganized, but we’ll get the details needed. Pics to follow.
Will add information as needed and requested, ask questions or make offers.
Prices exclude shipping unless stated otherwise.
Sachs Dolmar 133 super with 25” GB .404 bar and chain. Bought from a member here, rebuilt and ported. Chain brake does not work. $350 with B&C.
Would love to hand deliver this one would be heavy and bulky to ship.
Stihl 066 was a flat top saw but had a cylinder and top cover replacement before I bought it. Ported to be a worksaw, has been my go to for bigger work and stumping. Always put a smile on my face. $750 SOLD
Husqvarna 353 runs good, newish bar and chain. Cosmetically rough but mechanically sound. 158 psi compression.Metal intake clamp. I’m not a small saw guy, but this impressed me. $275 shipped in the continental US or make an offer? SOLD
Dolmar 7910 stroker. Ported and stroked to 38mm with a solo crank. Was built to race, will post a link to the build thread. Retired to work duty and does not disappoint. Great power at good RPM and has manners in its current state. Was a touch faster with RWJ carb but lacked manners and had no choke or air filter. RWJ can be included if desired. $900 PHO. SOLD.
Ported 7900. Started life as a fire department demo saw. Ported with an MS460 piston and runs real good. Stroker had a kinked fuel line for the races at Randy’s that year and this saw was my back up. Took 2nd place in class 1 and 3rd place in class 2 races. Did alright in the heads up racing as well. Since then it has had machine work to the flywheel to remove a good portion of the fins- this designates it as race only due to improper cooling but a flywheel replacement and she’d be a terrific work saw ready throw down for lunch money at any time. I have port work pics and video. $650 PHO. SOLD
Ported Husky 55 with Stihl 028 piston. Compression was ridiculous so the pop up was cut off. Aftermarket modified muffler. I lost interest in this one and hung it on the wall. Ran good when put up. $125 PHO. SOLD.
Husqvarna 298XP. Has aftermarket (VEC) piston. Ran great last time I used it. Metal starter housing. You’re gonna need your wife to start this beast for you.
. Largest bar I have is 36” and this saw pulls it with authority on an 8 pin sprocket. $475 PHO. SOLD
Copper piped MS390. This saw has made its rounds and many of you have ran it at GTGs. Fun saw, not gonna win any races, great torque and decent RPM. Currently has a modified carb to run Alky/ nitro at 10% but can be run on gas with a simple carb swap. I probably could come up with a gas carb too as any 1128 or 1127(?) series will work. $275 PH and pipe with some funny fuel.
Clone 660 build off saw. Took second place. WJ76 carb, OEM wrist pin bearing, fuel and impulse lines. Great overall saw, has been very reliable. I’ve run it in 6 cube heads up and also hung a 36” on it and put it to work. Top notch performance so far, but it’s a clone, so you never know. Can post a link to the build thread. $400 PHO
Piped clone 440. Second place at Randy’s build off. Has been passed around quite a bit at GTGs as well as some fun at the house. I messed around with an Alky carb at one point as well. It runs, but not like it once did. Has been overheated, probably needs rings, maybe a piston. $250 PH and pipe.
Husqvarna 272 - see details and pics in later posts. $250 SOLD.
Stihl 011 - SOLD.
more to come.
Stihl 011 - SOLD.
more to come.
