- 7:39 AM
- Mar 13, 2022
- Interior Alaska
Question for the saw porters:
When I ported my cs 8000, I didn't have a right angle piece to work the upper transfers. But on 2 tree jobs, I've bore cut heavy-leaning saw logs with a 28 inch bar/c83 chain and a 36 inch bar with full house 3/8 lgx chain!
Both saw logs were so big, the noses of the bars barely poked through the bark. As I square up my hinge wood or begin cutting out what could barber chair, the saw comes right on step when chain is leveraged tightly against the wood. You don't have to baby into the cut. It got all this low end torque and I REALLY like how it cuts on the job!
Its tuned at 13500rpms no load and is a tiny bit rich. I can't distinguish a difference from a 28" bar or a 36" bar, it pulls the same. I also cut down stumps with this saw, and it feels no different bar tip burried with full house chain.
If I fiddled with or raised upper transfers, would I loose that low end torque? To get more air/fuel to the saw, I upgraded to the larger HDA 45 carb. So I've got the carb to feed this saw.
