Gypo Logger
- 9:48 AM
- Jan 4, 2016
- Yukon Canada
I took in a 395 cause it wouldnt run. The owner said he had rebuilt the carb and may have done it wrong. So that is what I zeroed in on, but after i rebuilt it there was no difference, just an intermittant pop.
So I removed the starter cover to check the coil and noticed the high tension lead was routed under the plastic face plate instead of on top where it should have been.
The flywheel wore a bare spot in the spark plug wire causing the intermitant spark.
Has anyone else been stumped by stuff that was misdiagnosed?
John
John
