Saw builds
4:32 PM
Thanks for that Jason.
I think it is the opposite guys, when that valve opens I believe it feeds the Hi speed jet.
That big cube saw is likely creating more vacuum.
trooney
Admitted Woodaholic
4:32 PM
The land of pleasant living
I think it has to do with the pressure exerted on the diaphram and if it "pops "before a certain pressure is reached it floods the engine with fuel because not enough air is going through the carb to mix with it. Dont hold me to this though as I am just learning myself.
Chainsaw Jim
Con Artist LLC
1:32 PM
Springfield Oregon
You're on track.
The loading up or leaning up out of the cut like that is a sign of too much air to fuel. There are several ways to accomplish this...air leak from anywhere between the carb and cylinder gasket or transfer covers, bad fuel tank vent, line, or filter, improper carb adjustment, improper carb pop off as mentioned, bad carb kit, pinched fuel line, running out of fuel..
4:32 PM
And that gives it more fuel at idle?
Can you explain how it works?
I wondered about this also. But someone posted the hows and whys in a thread a few days ago. Seemed legit at the time, but it goes against how I thought they worked.
One thing about it, it'll either get worse or better, and then we'll know hopefully. Pretty sure J will post his findings to get us squared away
jmssaws
Banneded
3:32 PM
I can tune it fatter on the low and stop it but then it 4 strokes in the wood, low side is very touchy and more seat pressure helps it lean out on the high and keep it from being hungry after a cut.
I think. Lol
I've had a few do it and it fixed everyone
