Saw building 101?
LAWN BOY
Pothole
4:41 AM
Merrill, WI
I'm getting a Stihl ms250 from my uncle for free, needs a new piston and maybe cylinder. I was leaning towards using aftermarket parts... Any recommendations on pistons and cylinders on a budget? I'm tossing around the idea of doing an all out build and learning some more stuff while I have it apart. It'll be my first rebuild. What's involved in porting? What tools would I need to do it myself? What about dying the plastics? I'd like to dye them black, what materials would I need for that? This will probably be a project for this summer, but we shall see.
GMB74
7:41 AM
Vermont
Dying the plastics is simple. Clean them up well, get some Rit dye and a big pot of water, follow the directions on the package.
Aftermarket parts are always a gamble. I have used the cheap no-name pistons and cylinders off ebay and they have worked. But maybe I have just been lucky. Using name brand parts like Hyway may increase your odds, or maybe not. Check the return policy on whatever you buy. If you are going to port the cylinder, you can get by with a lesser quality item because you are going to grind out the defects anyway.
Someone should be along shortly with more specific information regarding porting.
Get the shop repair manual to have handy in case you run into a snag when rebuilding.
GMB74
7:41 AM
Vermont
It's not worth a lot of money, that is true. On the other hand he doesn't have to invest a lot of money. Aftermarket parts are cheap and generally of decent quality for this model saw. If it doesn't work out or blows up, he hasn't lost a lot. Just the cost of tuition for his learning experience.
Here's a thread with some good cheap and easy upgrades, once you get the engine repaired:
hacskaroly
2100 Fanclub Member
4:41 AM
Northern Idaho, Ehh
Here is a video of a guy porting a clamshell Poulan (similar to the MS250), should give you a good idea of what you might need and how to tackle a porting project.
