Now you are set up to use an easy out. Tractor supply sells them along with most auto supply stores. The tricky part may be the locktite. You may need to use some heat to get it to turn loose.
it's drilled way off center, that won't work
The most common method I use in the car world to remove bolts snapped off in aluminium engine components is to weld a flat washer to the bolt. Then a nut to the washer. And turn it out.
I told the mechanic it prolly has loctite in it seeing as how the other nut had gunk in the threads and was so tough to remove(it's for a coil mount). I suggested a map torch to loosen it up(which is what he has). They go for 100€+ here btw. So, I didn't bother buying one just for this one instance. Since he is a mechanic, I assumed he's had to do this a few times already. Apparently, he hasn't. I mean, the hole isn't even drilled square. It's at an angle, so prolly has damaged the threads, too. I'm not too pleased, but the man is a friend of my wife, so I haven't said anything yet...
I’ve done mine twice now on my 2500HD, 6.0L. They can be a SOB to get out! MIG welder to the rescue! We had to pull some ball joint sockets in a tractor MFWD axle. The factory didn’t machine the pocket deep enough to get the slide hammer jaws behind it, so I built it up with weld, then the thing just fell out! Heat helps on many things.GM's exhaust manifold bolts have loctite and are prone to breaking.
You would be amazed how many "mechanics" have never extracted a broken bolt.
We had a guy here try to sell brand new cylinder heads to a customer on a truck with broken exhaust bolts.
99 1500 5.3, about half the maifold bolts were broken off. A couple snapped a little deep. Same thing...mig welder, washer, nut. The splatter won't, and didn't, stick to the aluminum, so I wasn't worried. Funny thing is, after I welded them up, they pretty much turned out by hand. lolThe most common method I use in the car world to remove bolts snapped off in aluminium engine components is to weld a flat washer to the bolt. Then a nut to the washer. And turn it out.
You need a new mechanic. Nice of him to not charge you after making more work for you. Just sayin....So, I take it down to my local mechanic ...:
