Replacement Carb
TMan4557
New OPE Member
1:20 AM
Jacksonville
I replaced the carb on my Echo leaf blower, WYG-14, do I need to remove the plastice plugs so I can adjust the H and L ? What is the best way to remove the plugs if they are inserted?
Thanks,
Tom
EFSM
12:20 AM
Extreme southern IL
No. There are no plugs on that. It uses a small D shaped needle adjuster. One needle is in the middle of the rotor and the other is just below and to the right of the primer bulb.
