Removing bearings from crankcase
Mark71gtx
9:20 AM
Fuquay Varina, NC
OK, I spilt the case on the MS650 and the bearings were shot as I suspected. The crank pulled out and both bearings stayed in the case halves. How do I get them out without destroying anything, and do they come out toward the outside if the saw, or inside? Thanks!
Wagnerwerks
9:20 AM
Pa
Inside. You can usually drive then out with a punch against the inner race through the hole. Lay the case half mating surface on a couple layers of cardboard aka my bench top.... And have at it. Heat is your friend.
Mark71gtx
9:20 AM
Fuquay Varina, NC
Awesome! That is what I figured, but didn't want to damage the halves because I didn't ask. Thanks again!
cus_deluxe
terms of service violator
9:20 AM
Michigan
just be pretty careful of where the seal sits in there.
Mark71gtx
9:20 AM
Fuquay Varina, NC
I guess if I was looking at the flywheel side I could have answered my own question. Got them out. Thanks again!
Mark71gtx
9:20 AM
Fuquay Varina, NC
My shed floor is plywood. I use full size towels that we "retired" from home use. I folded it several times and set a half on it. Then the heat and beat. Went smooth as silk!
Jughead
9:20 AM
i actually invested in one of the small harbor freight presses.done pressed probably 10 saws since thanksgiving.kind of a tight squeeze but a life saver in doing a bigger volume of saws.
rattler
9:20 AM
NC
I don't know exactly were you at but I could have pressed them out for you.
Jughead
9:20 AM
A press is one of the best tools I ever bought. Mines also hf. My son loves crushing soda cans. He would crush everything I own if I allowed it.
i'd like to try it on some nuts.not mine of course.:D
9:20 AM
i have a press and my buddy is making me a few pieces on the lathe do press bearings out and back in i also use heat
rattler
9:20 AM
NC
Oh bud we bout 4hr apart I am in Marshall next to the Tenn line
9:20 AM
mine is like that and he is also making on to slide on the rod of my press and use a set screw plus a few seal drivers i have bought what DD sells but can never have enough tools
