Relevancy of Husqvarna 570 and 575xp loggers junk saws
Member
12:37 AM
I picked up 2-576’s and 2-575’s for cheap.I’m gonna try to get 1 running saw out of the 4. If you need any parts that you’re having trouble finding let me know. Hopefully I know what I got myself into with these, there may be a reason I got them so cheap 😂 I sure wish they were 372’s
Thanks, and that's a good haul you made.
Mendocino Redwoods
1:37 AM
Massachusetts
I would not hesitate to work on/run either of those two types again. Good saws.
I’m somewhat familiar with them. I had a 575 for a couple years back around 06-07. That one was just hard to get running right, seems like it always bogged and I wasn’t as competent tuning back then. The one thing i will say is that saw was one of the smoothest most comfortable saws in the cut I’ve ever ran
hacskaroly
2100 Fanclub Member
10:37 PM
Northern Idaho, Ehh
I agree, those saws have good balance. I ended up putting an AM piston and cylinder on the 576 and it has been running great (someone detonated the original piston putting a hole through the top and both ring lanes. I have another 575 to work on and am looking forward to seeing what is going with it.
Mendocino Redwoods
1:37 AM
Massachusetts
That’s good to know, what AM p/c did you use? I haven’t even had a chance to look at these ones, I have a couple other projects I’ve been working on. I’m hoping at least 1 of each cylinder is good enough to clean up. I’m trying to do these saws as cheap as possible, I need to stop sinking money into saws. I tell myself I’m gonna fix em up and sell em but then end up liking them and keeping them 😂
Member
12:37 AM
About all I have left over is a good non blown upped OEM 575xp cylinder, maybe we can do some horse trading?
hacskaroly
2100 Fanclub Member
10:37 PM
Northern Idaho, Ehh
Started working on the 576. Was told that "it wasn't running right". Looks like it was dipped in mud, but the piston and cylinder are clean. The carb had a crispy diaphragm, which I am sure that didn't help much.
I started cleaning the parts on the very left, will work on the cylinder and other parts tomorrow. The fuel tank is all nice and clean now too. I found an extra 576 carb in a box of parts and robbed the diaphragm from it. I have a few gaskets left over from a previous repair, so hoping to get this one running without having to buy anything.
Shane¹
1:37 AM
Kentucky
Make sure the throttle cable is opening the throttle all the way. May dad had several of these back in the day and the throttle cable would get worn and not pull throttle wide open
Mendocino Redwoods
1:37 AM
Massachusetts
I’m absolutely okay with trading! It doesn’t even need to be immediately, if you need something let me know and you can get me back in the future if I ever need something. You seem like a pretty respected guy on here, I trust ya 😂
hacskaroly
2100 Fanclub Member
10:37 PM
Northern Idaho, Ehh
hacskaroly
2100 Fanclub Member
10:37 PM
Northern Idaho, Ehh
It's as clean as it is going to get for free. I actually got the cylinder and the muffler back on today. I need to clean up the clutch and I can get it, the flywheel and coil, fuel tank, front handle and carb installed. Should be ready to test fire on Monday evening.
hacskaroly
2100 Fanclub Member
10:37 PM
Northern Idaho, Ehh
I put fuel in the saw, pulled 5 times, it burped, dropped the choke and it fired right up. I needed to do a slight adjustment on the low screw and idle, but the saw just purred. When it was time to rev it up, it didn't hesitate. I really like the power these saws have.
Earlier I stated that this was a 576, but realized later on its a 575. It is now ready to go back to work!!
David Young
Safety First !!!!!!
1:37 AM
vt
You know there is a website full of people like you....
your on it right now lol
I think it is called CAD.
