- 11:40 AM
- Jun 5, 2016
- Northwoods of Wisconsin
I had an old loggers junk 575xpg laying around for a while now and I finally decided to see if I could make it into something decent and usable for myself. I am in want of a bigger old man saw basically, that starts easy, has low vibes and decent enough power to pull a bit longer bar if need be. As of this writing, there's not a lot of support left for these saws, there is however some left for its close cousin the 576xp. Here's where we get into the fun part. While there may not be a huge difference between the two saws running them, the 576xp does have an improved lower transfer system which is the main difference between the two. This could be an advantage as I plan to port this saw, so it could pay off dividends later if I could make a 576xp cylinder work on the 575xp chassis. Question is will it work and be a legitimate saw when finished?
With my search engine locating me a reasonably priced new OEM 576xp top end and having to pull apart the crankcase anyway to replace the frozen crank with one from a near new 570 along with one fly side case half as long as I was at it to eliminate the repair on the old. I have the tools from Husqvarna already here for disassembly as well as assembly. So, might as well give it a go and see where it takes me.
The hole patterns of the top ends are the same along with everything else but the lower transfers. Here's how that story unfolded....
