MS261CM
I live on a heavily wooded suburban .7 acre lot and have two rentals that fit the same description. I had a DeWalt 620 that I used to cut up dropped branches and such. I bought the 261 just before an ice storm took down a dual trunk 80' Cedar. I limbed the Cedar with the lighter DeWalt and numerous battery charges.
The bar mounting hardware on that saw was torque limited to a level below that required to prevent movement. The bar would loosen up, throw a chain and cut up the plastic saw housing. I ordered a new plastic panel, filled the torque limit mechanism with construction adhesive and continued cutting. The brushless inverter eventually gave up and I trashed the saw. When it *did* function it bounced a lot due to the low chain speed you get with a 12V power source.
I know my needs and wants don't match yours but you guys know your equipment. My *big heavy* saw is the 261. I worked it hard at the stump of that Cedar but it handled the rest of the job with ease. For smaller tasks that I would like to handle quietly I would appreciate a suggestion for a quality battery saw. I won't buy another DeWalt. I have looked at Echo, Husky and Stihl.
The requirements are reliability, lighter package than the 261 and smooth cutting. A 12" bar would probably do. Does such a machine exist? What is it?
Also Stihl doesn't seem to want to share whether their small battery saws are brushed or brushless. Do any of you know?
Thanks in adv
Thanks in adv
