Recommend me a gasket material
JimG.
7:37 AM
NorthCountry
I have a couple old machines to put together and I am going to need to cut the case gaskets. I am looking for gasket material suggestions.
hacskaroly
2100 Fanclub Member
4:37 AM
Northern Idaho, Ehh
I use Felpro gasket material. You can get it at automotive stores, but usually get a better deal on-line. They come in flat sheets and rolls. Here is an example you can get from AutoZone:
AutoZone - Felpro Gasket Material
You can get different thicknesses depending on where the gasket is going. I don't think this material would work well for an exhaust gasket, but I have used it to cut carb gaskets, and various case gaskets for many of my saws.
David Young
Safety First !!!!!!
7:37 AM
vt
Great post, I use similar stuff from Napa. I have used that stuff on mufflers, it will work fine, I have never had an issue. but it helps to make sure the muffler is free flowing....
Depending on thickness and purpose I have used manilla folders, and brown paper bags for gaskets. I have also used thin aluminum cans.
hacskaroly
2100 Fanclub Member
4:37 AM
Northern Idaho, Ehh
Good to know, I just assumed (we know where that gets you...) from the muffler gaskets out now being a different material than the other gaskets that the regular material would not hold up. I guess I can make one up and give it a try and check on it every so often to see how it is holding up.
How long do the manila folder gaskets last? I have a saw that looks like it had one that thin for the cylinder gasket, but it was almost 80 years old and had pretty much disintegrated.
Sloughfoot
4:37 AM
Norcal
Local vintage motorcycle restorer swears by this stuff. Says it's the only thing he's found to keep tailpipes sealed to the cylinder on certain makes. Haven't used it yet but will soon.
lehman live edge slab
Live Action
6:37 AM
Mn
For exhaust gaskets I bought Mr gasket brand header gasket material. Came in 12” or so square sheets, looks like black felt and has a metal core. Otherwise just rolls of black or cork gasket material for the rest depending what’s needed.
JimG.
7:37 AM
NorthCountry
I like the look of that. I'm doing some pioneers and the reed blocks are really taking some attention to get sealed reliably. The oem intake gaskets seem to be made from a material that is thicker and softer, more conforming than the felpro stuff. I have been trying out a layer of 1184 to help but it seems like the recipe was changed and, although it is less annoyingly stringy now, I am not sure it is as effective. I'm going to see how the Dirko performs.
jakethesnake
I Am The Snake
7:37 AM
Here & Now
For case gaskets I’ve only had experience with felpro. Felpro is huge in the automotive industry for good reason. They make good quality gaskets. The other stuff fellas have mentioned I have no experience with but I would grab felpro
