00wyk
1:01 PM
Ireland
Have any ideas hwo we could go about adding one to a newish Case tractor without breaking the bank? Or are there any other options?
ETA - I was considering welding a motorcycle sprocket on to the thing and running a little honda engine to it. It has to be inside a shed, so would rather not go with two stroke :( Cough
Steve
Excellence!
7:01 AM
Learned early on not to use gaskets on old tractors because of pitted or warped sealing surfaces. When i built this engine i had to tear it all apart to throw away all the gaskets and use right stuff. This is the only sealant i use. Even holds up against trans fluid.
00wyk
1:01 PM
Ireland
I was thinking I might remove the wheel and bolt or weld on a v drive so I can simply hook up one of our old riding mower engines to it. 12HP oughtta power a buzz saw OK. It's just finding the time.
Harleydaze64
8:01 AM
Ohio
View attachment 234174 View attachment 234175 View attachment 234176
The only gasket in the engines that we make is a head gasket. Every other surface gets what you just used, applied by robots. It works great as long as the surface is oil/grease free upon application.
merc_man
merc_man
8:01 AM
southern ontario
I turned into a wood snob today. Farmer i know called me to see if i wanted some wood. Im takin all the cherry first. Probly for more loads like this one or more and way more white oak then i could ever take. He is clearin out a fence fow.
They gonna let me take it to ther farm to store some once im full here.
The good logs are goin for lumber.
