merc_man
merc_man
8:46 AM
southern ontario
Nasty wind storm popped up tonight. Nocked down a small tree or limb in the neighbours yard.
Bigmac
5:46 AM
Oregon
I bet that sounds nice. My truck cam is mild but just a small rumble at idle. 206/212 duration @.05", 0.486/0.489 lift. I built it for torque, it's basically stock except the cam and quench set to 0.028".
I want to build another engine some days
I bet it runs good! I build this to make peak hp at 7k an the internals at good for 8500, with the demon 650 it peaks at 6800 and the 850 demon 7100ish the 850 make better power anywhere above 2500 but the 650 is more manageable, and the drivability is better, the weird thing is the the 850 makes great power down low but the throttle is to touchy, and that makes it harder
chipper1
8:46 AM
Grand Rapids Mi
Well, it was a long day. Started out missing a call for a tree job because my ringer was off, that's okay as it was real hot, ended up doing tree work anyway and bidding a job o_O.
Then a link to pictures of the Honda generator I listed on CL today as well as, the first route I took to the town I did the tree I cut up, the second route I took, and the third which had just been opened up, the storm that drenched me while I cut the locust, the damage in the neighborhood I did the bid in, pole down in the park where the other covered bridge in our area is located, the bridge(moving too fast :(), a power pole that was burning after the fire dept had already been there(I called 911 on that), and a couple more trees that were down before my phone died :eek:. I did run one of the the ported 346's and a modded 2171 on the huge branches at my house when I got home and hauled the largest branches to the bonfire pit supply area :).
https://photos.app.goo.gl/zrcxiXNGazMNKdzz5
Here's the little bit I did, a large Black Locust across a drive, ran the ported 2166 with a 24" couldn't make it thru at the "Y". I like the address, it's a red saw address, 2150 you can see it on the left white fencepost :b1:. Also one of my fav pics to take is putting clouds into openings, kinda like playing Tetris :D.
Screen Shot 2019-07-21 at 12.07.01 AM.png Screen Shot 2019-07-21 at 12.07.47 AM.png Screen Shot 2019-07-21 at 12.18.41 AM.png
Bigmac
5:46 AM
Oregon
Was wrenching DE1FCE16-B917-4E7F-95F6-129E05643D2E.jpeg84C54E72-5D92-41E0-86DF-AB974C42A359.jpeg
I put a small dirt bike radiator on the banshee, getto mounted, I even put tape over it to keep it warmer, lowered the gearing one tooth as well, going to test tomorrow
chipper1
8:46 AM
Grand Rapids Mi
Was wrenching View attachment 191758View attachment 191759
That sounds like fun testing it, heck working on it in the temps out there would be pleasant too.
Glad that front came thru today or it would have been nasty.
