Bigmac
10:33 PM
Oregon
Some tree cleaning….57F873F5-4A64-4219-8253-53CC3A1E157B.jpegE157A487-9CA4-4BCC-884B-B0864A3D8CEC.jpeg Beach grown Douglas fur can grow slow, about 75 years old!
Got my new pegs for the r, they were pretty reasonable D8032B05-1A8C-48F1-B1D6-8FBFFF489F36.jpeg89B17B19-ED1C-43A5-8831-11CCA9059CE0.jpeg
Got a rush fix on a trx450, wouldn’t start, nothing worked, but you could bump start it or take a screwdriver and jump the solenoid, and it would crank too, so I tested the key switch and it passed. Removed the rear plastics, and I checked the fuses and they looked good at first glacé, but I tested them with a meter and it failed, can see it on the close up92437DC3-4B66-4EB5-8EC5-49510CF4B9B0.jpeg
CrystalRiver1
12:33 AM
Alabama
vtrombly1
1:33 AM
Richmond MI
Timjus
8:33 AM
Finland
snow storm aftermath wheeling
picture.php
Only the Tony
12:33 AM
Little valve cover gasket time on the 30 valve. I have cross contaminated the German car with stuff for J.A.Pan autos. Think someone has been in on the passenger bank before. No sealant around the camshaft caps and the nuts were super tight.
vtrombly1
1:33 AM
Richmond MI
magneto fired
batt just starts it
Yes, unless like I said the charging system is malfunctioning and it quits midair after the voltage drops from the malfunction. When you jump start you effectively charge a dead battery. If the charging system is bad it will continue to run until the battery drops below the voltage required for it to run then it just quits. What your saying will work assuming someone left the lights on and it's a weak battery that will accept a charge. If it's a bad battery even with a good charging system you shouldn't be using it with a bad battery as doing that will destroy your charging system because it can't charge a bad battery which causes heat because there's nowhere for the voltage to go and blows out your charging system which will again cause the motor to stop.
Pincher
12:33 AM
sw corner of twin cities mn
magneto fired
batt just starts it
What your saying is if the plane had a large pull start like a chainsaw, it would start and stay running like a chainsaw regardless if there is a chaging system or even a battery? No wonder more planes don't crash.
Woodslasher
Teh debil
10:33 PM
Commiefornia
What your saying is if the plane had a large pull start like a chainsaw, it would start and stay running like a chainsaw regardless if there is a charging system or even a battery? No wonder more planes don't crash.
Haven't you seen the war movies where the guys flip the props on the fighter planes to start them up?
vtrombly1
1:33 AM
Richmond MI
If the battery has expired, no amount of engine running will charge it. Also, it could destroy the alternator if the battery's failure mode included an internal short. This sets up a potential chain of failure where the avionics, lights, and electric flaps are inoperable. Night? Short runway? No way to broadcast MayDay? (Bold pilots don't become old pilots.)
bigbadbob
10:33 PM
Interior BC Canada
Magneto dont care bout anything but itself,, just keeps on sparking,, and usually has a backup as well.
Im not sue if the guy left his lites on or the battery is fubar,, he still owes me beer.
