Question for the porters
StihlEchoingHusky
6:28 AM
Question 1 do you know if there is a Dremel style right angle flex shaft? I don't mean the fortiflex model but like the normal attachment type. Not that I'm after one just something I'm curious if exists
Question 2 any of you seen something like this? Almost looks like the burrs head is attached to a inner flex shaft and then you bend the outer to fit your needs. I doubt they would last long especially if you needed a 1/8 shank or 3/32 and they look difficult to control. They'd probably snap almost instantly if bent to 90°Screenshot_20240924-202411.png
srcarr52
9:28 AM
Iowa City
There are no dremel attachments that will fit into a chainsaw cylinder.
That setup has the burr attached to a flex shaft running through a bendable sheath. They are for very limited, get yourself out of trouble, uses.
StihlEchoingHusky
6:28 AM
You have any experience with one? I figured it was a end all solution kind of thing. The head on that one is massive! I did have a 1 inch double cutt ball at one time. Also for *s-words and giggles I had a 2 inch diamond bur 🤣for chamfering uses obviously...
srcarr52
9:28 AM
Iowa City
I've seen things like that used for porting intake manifolds when there was no other choice and only a small amount of work needed to be done on something that couldn't be cut apart and welded back together.
