Putting a new spark plug terminal on an ignition wire
kneedeepinsaws
1:43 AM
Oil Country
I tried once and seemed to fail, putting on a new spark plug terminal for a new coil i got.
its for a chainsaw in which the terminal literally pierces the ignition cable in the center to make contact with the inner wire.
I used a pick and tried to pierce the centre pf the wire to make a new hole, but ended up severing some of the outer strands of the wire... I ended up soldering it on, but I dont trust the bond that I made.
is there some trick or tool to pierce the wire to make a hole for the terminal?
I have enough cable left to make one more attempt, after that its gonna be too short.
Thanks for the help
Lone Wolf
3:43 AM
Nj
Take a needle nose pliers and squeeze the point on the terminal into the wire. Hold the wire and the coil together and squeeze.
Thanks for the help
fossil
3:43 AM
Ontario, Canada
The terminal spring should be cut at an angle to make easier to insert. They should come that way.
brad ruch
3:43 AM
michigan
Husky makes a pair of pliers to do this.if ya wanna spend 40.00[emoji23][emoji23]
Sent from my Pixel 2 XL using Tapatalk
CrabAlley
Active OPE Member
3:43 AM
MD and SC
Hey, I also wrap the terminal with a short piece of stainless stranded picture wire, like a safety wire, make it tight as possible, then install rubber boot, then a small zip tie over the rubber boot.
Carhartt
3:43 AM
Central Pa
I electrical tape the terminal tight and spray lube the inside of the boot. This is another one of them "I cant believe we still do it this way" things.
JB-PlantHeirloom
3:43 AM
Georgia
It is one reason I dread working on my MS-6660 clone, they took a bad plug wire design and made it worse.
On mine, I will probably put an automotive type boot on it using the spark plug wire tool compressor/crimper I received inside my MSD generic spark plug wire kit. Basically you take the lead, fold it over, crimp a metal (not spring) connector on and then slide the boot down the plug wire over it.
