Woodslasher
Teh debil
- 12:39 AM
- Mar 18, 2021
- Commiefornia
I was assembling an 056 with a 54mm top end, and I had a Proline piston on the bench that I was going to install. I had bought an 056 Mag II piston from them a few years back and it seemed to be close to oem quality. This one was packaged differently and had a bit of casting flash, which I cleaned up. When I went to install it, however, it has a good 2-3mm of side to side play on the rod and it is unusable. When I looked at the box, the Proline label is slapped over a generic "white box" label, similar to the ones you see on LRB piston boxes. I will be doing what I should have done in the first place and ordering a piston from The Duke, but I wanted to give y'all a heads up about this issue first.
