RIDE-RED 350r
- 9:06 PM
- Feb 8, 2016
- Blossvale NY
So, my father in law gifted me a 1980 Chevy 454 with what I think is a B&M 174 blower. It needs pistons and a bore job seemingly due to not being built/set up properly for the mini-blower.
I'm planning to keep things kind of modest with the boost and want a good reliable engine with excellent lower end grunt for duty in my '78 Chevy K-10 with the SM465 4spd transmission.
What I think is part of the problem is that I'm told it has 366 BBC heads on it.. I plan to hunt up some proper 454 iron heads for it. Also, even though the rotating assembly has very low hours on it, I plan to replace all the bearings since the block will be stripped for cylinder boring.
Aside from that and as I said, I'm looking for a good "truck oriented" mill in this setup. I won't be drag racing or looking to spool 7k RPM with it, I will be pulling my trailers and just general driving and want a good meaty torque curve that comes in early in the RPM range.
Also, I'm not going to have a $15k budget to work with here, so...
I was looking at I-beam rods rated for up to 750hp for BBC, those seem like they will do the trick. I think of this ends up making 500hp that would be an accomplishment and my goal is at least 400hp/400ft-lb.
Pistons: any recommendations?
Heads: any recommendations? Not looking to spend $3g on a pair of heads...I plan to lean on the blower a bit to make up the difference...
Carb: I'm sure the Edelbrock 1406 (600cfm) AKA: Carter AFB I have on the 350 currently in my truck won't adequately feed this moderately blown BBC, leaning toward a Q-Jet.
Also, I need this to run happy on 91oct as this truck is my summertime daily driver.
Any thoughts on the blower? I know it's a B&M and after looking around online I think it might be a 174. Other than that I can find no markings or numbers other than B&M.
@TJthesawmechanic
@TJthesawmechanic
