press in wheel bearings all the same on lawn mowers?
r7000
8:02 AM
CT
have a husqv. HU800HW, bought from lowes ~10 years ago. Has the larger diameter rear wheels, and the rear wheels have the press in bearings - two of them per wheel. Are those all the same? Want to replace them, and I did this on my honda hrx circa 2005 a few years ago. Can find those bearings on the parts diagram for honda, but not my the Husq HU800HW. Thinking I might wing it with amazon "lawn mower wheel bearing", are the odds in my favor or against me?
Moparmyway
Its just a saw
8:02 AM
In a meeting
I’ve seen different bearings, but if they need replacing and you have no other options, you don’t really have anything to lose.
If they don’t work, you can try measuring (with calipers) the dimensions of your existing bearings and see if you can match them up with any of the bearing manufacturers
GMB74
8:02 AM
Vermont
There should be some numbers stamped or printed on the bearings.
Pop them out and check, then get bearings with the same numbers off ebay/amazon.
If there are no numbers, then you will have to measure them and go from there.
