Poulan 5200 hotsaw
p61 western
Ol Mudflap
1:46 PM
GFY
I'm happy so far.
All the fins on the back of the cylinder needed cut shorter for clearance so a heat shield will fit in between it and the carb, but never installed the heat shield. It sure didn't like it when that carb heated up, lol.
I haven't burned any alcohol in it yet and still need to have a pipe made.
It's going to be bad azz for sure. Love the old school builds.
3:46 PM
I'm happy so far.
Oh my that thing is really gonna scoot
Chainsaw Jim
Con Artist LLC
1:46 PM
Springfield Oregon
I think this thing is coming along nicely. I fiddled with the carb a little more, fixed the air leak, and fixed the tank vent. I'm still needing to work out a couple behavioral problems with the idle down. It may be just too much carb unless running alcohol makes a difference.
This time around I decided to run a 10-pin sprocket with 3/8 chain. I was very surprised with how it pulled it.
Deets066
AKA Deetsey
4:46 PM
Not sure if you have those stores by you, Hobby Town, Hobby Lobby. They have nitro mix for rc trucks
Deets066
AKA Deetsey
4:46 PM
Acquiring the hardware wasn't what I had in mind when I made the comment.
Running alcohol you need 2-1/2 times as much fuel. Bigger fuel line normally, and gut the fuel filter.
What carb do you have?
Lightning Performance
4:46 PM
East of Philly
Rich on top lean on the bottom.
Dump the timing back and keep the compression reasonable for 20%. A hotter plug might be needed might not.
The main jet usually goes lean on gas carbs. Flood carbs cover it up.
4:46 PM
East of Philly
How bout a spacer on the carb plate to hold more fuel also
Drill the inlets and tri-point the needle. Drill the needle seat.
I don't use a larger bowl to cover up a fuel delivery problem.
Case in point. Drag racing a single float Carter 750 carb. They never run out if they are done correctly for proper fuel delivery.
Edit: fixed it, twice, whew...
Lee Stiltner
Active OPE Member
4:46 PM
Pikeville, KY
I've just aquired my first 5200 and I am tickled pink. Was curious about mods I could do to improve performance without going all out like you? Any ideas would be appreciated. Thank you so much.
Lee Stiltner
