Post up your ported cylinder Artwork
Nutball
11:56 PM
Mt. Juliet, TN
So far so good. Put a half hour runtime on it last night. Ring pin is centered over the intake port. I saw it on the internet so it's gotta work right? LOL
I actually got to thinking last night about how wide I make transfer ports sometimes. I was going to check some of the cylinder kits I've practiced on today.
My concern with your cylinder was if the upper transfer is flat across the top and wide enough, it could catch a ring.
How wide does a flat port edge have to be to catch a ring? It would be nice to have a rule of thumb for the limit of width and minimum radius to avoid catching a ring.
Most rings have rounded edges which will wear off until it sharpens them razor sharp (even near 90 degrees). Then maybe that could cut away at a chamfer until it slams to a stop.
Ketchup
Epoxy member
10:56 PM
Colorado
In the case of a transfer upper the ring is also expanding into the exhaust port and the other transfer at the same time.
If 70% of bore is the ragged edge of port width, seemingly 45% of bore would be a dangerous amount of flat port roof. I’m not sure how multiple ports changes the equation. In the case of transfers more volume isn’t necessarily better so going wide might be a problem even if the rings are fine.
But hey, fingers and bridges are fun! Looks cool! I hope it rips.
82f100swb
11:56 PM
Dryden, ON, Canada
This was entirely a junk off of the shelf build. Cases and tank were my ugliest 61 set that wouldn't have been saleable, top cover is aftermarket junk that didn't fit anything.
This is entirely just for fun. If she stays together I may build a pipe for it.
12:56 AM
046 jug for a hybrid. This is one of those D jugs that had perfect transfers after machining at 121*. Smoothed some stuff out, but tried to not remove too much from the transfer tunnels. The intake roof is untouched, but that chip still needs to be chamfered. Should be a runner.
I may still “Deeter” the lowers. Deciding.
F1C86D37-7078-47E5-A5A5-761F791DCA37.jpeg F2F85E96-EF35-4813-ABA8-C98AB3B6856D.jpeg 9962350A-AE1D-46EF-8B5C-25C0C147AA74.jpeg A7CA17B7-9226-4215-AFC8-7CDFF20995C6.jpeg 1DA2EB34-072F-4C37-94B0-6A84CB8A9200.jpeg
12:56 AM
Al, is it an optical dilusion, or did that jug have a real flat exhaust roof?
