- 11:05 AM
- Dec 30, 2015
- Brewster, NY
Even if you don't go backwards you may hit a point of diminishing returns, or as I've heard Randy put it "your just making more noise".
And although it was not tested, at that point I believe fuel efficiency will also start to suffer, which is an important factor to anyone who cuts for a living.
Unfortunately, I think the only method we have is testing and trial and error for each saw.
I also have a ported Asian 660 that seemed to like the baffle when it was first built, but then ran better w/o the baffle after it was broken in. Likely it picked up a few RPMs and that made the difference.
I think most of the builders figure out what works for their style of porting and stick with it. In general, ported saws will benefit from less restrictions.
