Pneumatic blowgun
junkman
Crush it
12:26 PM
pacific northwest
OK, whatever I get I'll be sure to choose appropriate nails.
On another note, is a water separator/filter something I should worry about? Or is that more for the hardcore 10-hr a day types? I know if I was going to be painting that would be one thing, but I am only using nail guns and the like at this point.
You will not need one ,just drain the tanks once in a while .
Milkman31
2:26 PM
Tn
I wish I had one with an 8foot wand!!! To keep the saw grit off me.
czar800
3:26 PM
Ellwood City
Got a picture of the blow blowgun I use on the combine and other equipment. It also works pretty good at sweeping the floor...
Anyways it's 4' of 3/4" pipe with a ball valve. The handle that has the wing nut looking set screw turns and slides up & down the pipe and locks with the homemade wing nut.
junkman
Crush it
12:26 PM
pacific northwest
One of the tire stores here had a pipe with a valve like that in it ,they hooked it to the 1 inch air hose for truck wheels ,would drop valve stems in it and open the valve ,those things shot a long long ways ,good 1/4 of a mile .
skidooguy
Genuine smartass
1:26 PM
Wyoming
I have one similar to that for the combine as well. Very nice because barley chaff sucks to get covered in. I also have one called a radiator genie that is amazing for air filters and radiators obviously. I'll see if I can find it on the internets and get a link posted
3:26 PM
If you are going to spray paint a good water trap is a must .Else the paint won't come out so good .
My shop is piped with 1/2" black iron pipe .Below each air chuck I have 12" of pipe and a ball valve to drain the water .Plus I have a large trap on the discharge of the two stage compressor going into to two 60 gallon tanks .140 PSI on 165 off .
