Pictures of ms 362 cylinder/piston failure
D B Cooper
44:1 Bel-Ray MC1
7:57 AM
somewhere
Ok I have never seen a failure like this one before.
On with the carnage!
I see where the plating has been worn off the bore at TDC / BDC .
Stevetheboatguy
6:57 AM
Nw IL
Not positive, but the cylinders that I have seen worn like that are usually on newer strato saws. I'm going to guess it's due to the piston balance and the way it rides in the bore. They generally have a longer skirt on the intake side and seems to create more wear than what we are used to.
The piston looks like it ate the locating pin? Is that correct? That's usually due to fatigue or heat in my experience.
Steven
Fruecrue
certified hand catcher
7:57 AM
Alden NY
Weren’t some huskies doing something similar? Maybe 562s? I believe they determined ring flutter was root cause to the pins coming loose.
Marshy
WFO Cutting
7:57 AM
Mexico NY
Ring flutter comes from over revving from my understanding.
D B Cooper
44:1 Bel-Ray MC1
7:57 AM
somewhere
The locating pin is still in there, it is worn away.
original cylinder, saw d.o.m. is 6/14.
I notice the ring with the flat edge was broken off. Wonder if it got a chunk broken off at assembly and rattled around in the groove till failure?
7:57 AM
Left ring pin broke off and the ring end moved over and caught in the transfer port
Chainsaw Jim
Con Artist LLC
4:57 AM
Springfield Oregon
I read that it's from trapped gas between the rings interfering with the ring tension against the cylinder wall. It says the remedy is to take the lower ring and increase the gap enough to vent a little bit.
Bigmac
4:57 AM
On a cr250 but still, the ring looks like it’s missing but..706CEC8A-21E5-4746-BD15-508A570B7279.jpeg
AlfA01
2:57 PM
Evia, Greece
Yep. It looks like it beat around in there for a while before it finally hung the transfer port.
I've also read that some of the 560/562 piston ring pins become loose and recess into the piston. They allow oil and gasses to pass behind the ring which gives a false high compression readings. Whether it's gas or fluid, I can only imagine that would cause a hydraulic effect with the rings also.
D B Cooper
44:1 Bel-Ray MC1
7:57 AM
somewhere
Found the updated cylinder and piston from a type 2 installed caber rings. used the new carb box and version 3 m-tron carb and coil. don't like the new 10mm sparky plug,another i have to keep in the spares kit. Tuning with the new version 3 is easy. got 4 tanks thru it so far it keeps getting stronger.
AlfA01
2:57 PM
Evia, Greece
Cool. Nice username by the way. Did they ever catch that guy?
