Picked up old grinder looking for input for wheels
jakethesnake
I Am The Snake
11:59 PM
Here & Now
IMG_5422.jpeg5 inch wheel seems about right 1/2 arbor
I have another set up with wire wheel and course stone.
Figure I might sharpen some drill bits and wondering about wheels. Good wheel’s suggestions. Just general purpose grinder
blades
10:59 PM
Leroy, WI
for just touching up drills /tool edges 45-60 grit about I hardness, for hogging 20-40 grit g hardness , hardness of wheel varies with speed a bit also make up of wheel will affect that also . vitrified wheels are harder than resonoid wheels. A=soft- z=hard scale wise. Garden variety wheels at hardware store will likely do just fine, most of the time those are just stated as fine , medium, coarse. As the grit gets finer the wheels act harder. one can spend a lot of time researching grinding wheels , it is a science in its self. And just to add a little spice no mfg is just the same as the next . I have wheels made to my specs, even there it varies a bit from lot to lot. With the crazy way things are now days I have to plan a minimum of 12 weeks in advance of what I will need.
5:59 AM
I just go by: white, pink, grey (coarse, for steel), orange, brown, grey (fine, for carbide) :p
I used to know to "read" a wheels composition specs, but I forgot all of it. :(
5:59 AM
White wheel, good for HSS/SS
Grey semi coarse wheel, good for alloyed steel
Grey coarse wheel, good for soft steel
Fine grey wheel, good for Solid-Carbide/Tungsten/WiDia
5:59 AM
Wheel for belt saw grinding (high alloy steel, SS), works great on chainsaw chains aside from being a little bit coarse.
Doesn't "burn" the chain cutter as easy as a "pink/salmon" wheel
Kinda hard to read, Weiler A60LM6V
5:59 AM
Gang saw grinding wheel, can't make out the specs.
I'll ask my neighbor to check on a new wheel.
Brown wheel, quite fine grit, haven't tried it yet.
5:59 AM
Where is the fun in that?
Like using ONE saw ever! ;)
