WANTED Panther bars
Evansaw
6:02 PM
Greece
Hi, this one mainly for arborists
Are you around Panther bars? Those "evil" 1/4 stuff? I m interested about 16 and 20 inch for Stihl 3005
Ketchup
Epoxy member
9:02 AM
Colorado
I’ve had sprocket durability issues, but 16” is the longest I have used.
Evansaw
6:02 PM
Greece
Actually i was thinking 16" for my 151T and 20" for 200 and 201
Ketchup
Epoxy member
9:02 AM
Colorado
I don’t think Panther bars are sold in the US anymore. I think they can still be had from the UK.
lehman live edge slab
Live Action
10:02 AM
Mn
just curious but why so long? reach? sure seems like anything longer than 16" would be a pita for in tree work. local tree guy tried a panther bar lasted like 2-3 weeks so back to stihl bars on his saws.
Ketchup
Epoxy member
9:02 AM
Colorado
I ran an 18” .325 nano on a 201t for a day. Hated it. The rear handle is much easier to operate with longish bars.
Evansaw
6:02 PM
Greece
My standard is 16" 3/8 on 200/201T
Thought to use 16" on my ported 151T and convert 200 to 1/4 using 20" for removal
Today i switch from 200/201 to mastermind 261 with 20" or go straight to 064/661 with whatever length needed
Live Action
10:02 AM
Mn
My thoughts is what your doing now would be better more handy than a 201 pulling a 20” bar. No im not a climber so I don’t know from experience just seems all the tree guys I fix saws for are doing what you do now. 201/200/194 on limbs and smaller trunk portions then say on a pine or something else large they go to a 261/362 and then 500/661 on ground. Just can’t see a 201t with a 20 on it being much fun to work with.
Ketchup
Epoxy member
9:02 AM
Colorado
My go-to removal progression is 14” (2511t), 20” (261), 28” (372), 36” (395) or 42” (395). I do almost all my brush work with 14”. I went to 16” for a while, but it bothered my elbows and didn’t really change much in efficiency.
Personally, I’m totally disappointed in the panther bars. Just not durable enough.
Evansaw
6:02 PM
Greece
Well there's the Fun & Test Factor somewhere there but since the bars are crap i m not throwing money to garbage
Evansaw
6:02 PM
Greece
Then i totally abandon those bars
Do you have in USA the 3005 Stihl bar 1/4 at 16 inches?
Ketchup
Epoxy member
9:02 AM
Colorado
I think so but they aren’t common.
You hated it because of being nano or being 18" long?
The length. If you think about it, a rear handle saw has a greater distance between your hands and they’re more or less in line. On a top handle your hands are much closer together and side by side so controlling the end of the bar requires more force. Your trigger hand does a lot more pushing, even when you use the dawgs. You’re typically making your face cut and back cut from the same position when climbing, so you have to back bar a lot more. Longer bars are just more awkward and tiring. I might be biased. That whole day was a bad experience.
The nano teeth are pretty good but the safety rakers suck.
EFSM
10:02 AM
Extreme southern IL
Sounds fair and logical. You've got very little mechanical advantage with a top-handle.
As far as rakers go, it seems like chains may eventually get so safe that they can't damage wood.
Evansaw
6:02 PM
Greece
Gets the job done
stankers
11:02 AM
SC
Chainsawbars uk has 10 packs of 16” bars for around $100. When they are roughly $10 a piece you don’t get so mad when you blow out the tips. If you keep them greased I feel like they last a little longer. Shipping is incredibly fast too. I get them to the east coast in about 3-4 days.
