Oregon grinder stopped working
EFSM
4:22 AM
Extreme southern IL
It could be in the switch, although I don’t know what your setup is. I have an old Foley Belsaw grinder that would just hum but would start spinning if you flicked the wheel. Turned out the switch had two circuits, one of which apparently supplied the capacitors, and that part of the switch had melted. I repaired the melted switching plunger with a fitting from a plastic primer base, which worked for another few years until the switch burned out entirely.
