Olympyk 945 oiler o rings
rshawcityman
Active OPE Member
2:06 PM
Hanford CA
I have a 1985 Olympyk/Efco/Oleo Mac chainsaw. I need to replace the seals on the bar oiler pump. I have found the basic o rings but it has 2 x rings or square o rings i cant find. It measures 7mmID 9mm OD and 2.2mm high. The picture shows its not just flat but its not exactly x shaped either. Does anyone know where i could get these?
Dustin4185
5:06 PM
East TN
We have a local seal company in Knoxville that can get about any o-ring or seal out there. They also custom make them if they have the right size stock.
Signal industrial products is their name. Maybe you have something similar near you.
hacskaroly
2100 Fanclub Member
2:06 PM
Northern Idaho, Ehh
Welcome to the forums! Do you have the model number for the saw? With that we can look for an IPL (informational parts list) and see what the part number is and possibly find it that way.
Edit, nevermind about the model number, I just looked at the thread title...
rshawcityman
Active OPE Member
2:06 PM
Hanford CA
rshawcityman
Active OPE Member
2:06 PM
Hanford CA
Thanks, Here's the exploded parts list
hacskaroly
2100 Fanclub Member
2:06 PM
Northern Idaho, Ehh
Yes mine is the 945af but that looks like the seals although that pump looks a little different
Ok, well that at least gave me a better idea of how that type of o-ring is used having not taken an Olympyk apart. I looks to be one of those rare to find parts. Probably best bet is to keep watching e-Bay and waiting for an oiler assembly to show up and get it that way. They might end up being in good enough condition to just swap the assembly and not have to remove the o-ring and risk breaking it.
I am running into a similar situation with some air filters and other parts...getting to be really challenging to find.
