Old Tilly Carb Question
Chainsaw Jim
Con Artist LLC
10:17 PM
Springfield Oregon
When the velocity of air flowing through the carb reaches a certain level from high rpm it releases excess fuel to flood and slow the engine.
You can disable it by plugging the passage beneath. Most use a small cut out of aluminum can. Drop it down there like a washer and tighten the brass plug back down.
It's there for good reason. If you're not needing a hotrod then only do it temporarily to tune the saw when you don't have a tachometer.
redtractor
1:17 AM
Maryland
OK. Sounds like another passage to keep in mind while cleaning. Thanks
