Odd porting, ever seen this?
Spladle160
11:29 AM
NOVA
Saw this picture and can't quite imagine the effect. Anyone seen anything like this?
Nutball
10:29 AM
Mt. Juliet, TN
I could be wrong, but I don't think it helps much being 90deg to the direction of the flow unless the intake port was widened, but still... Everything seems wrong with that idea.
11:29 AM
Seems like case compression might suffer. But at high rpm the rush of intake air hitting the closed intake might kinda stuff the transfers, too. Interesting
Nutball
10:29 AM
Mt. Juliet, TN
But according to the intention of the strato ports, that would waste gas and save fresh air with no increase in power right?
11:29 AM
Not sure. I suppose it would depend on whether the rush of mix was under the strato air or above it or maybe mixed in with it.
It’s unusual that that was done without any work to the lower or upper transfers. I usually unshroud those quite a bit in a 362
Spladle160
11:29 AM
NOVA
Not my work, not my saw. The saw was for sale and listed as ported so I asked for pics. The skill of the grinder looks reasonable but some of the theory appears to be... different. I wasn't going to drop any money on the saw after seeing it but it sure peaked my curiosity on the theory. Different is interesting until you have it figured out good bad or indifferent.
11:29 AM
You would almost have to run it to see how good it was. I could honestly see that going either way. On one hand, like I mentioned earlier, If that fast moving air is slamming against that piston when it’s closed that could really be charging the case.
Nutball
10:29 AM
Mt. Juliet, TN
The 201t almost has the same thing going on, but on the piston. Maybe it charges the piston pockets with gas mix to get a smidge more power behind the fresh air. Maybe it is just to let a little oil in to help keep the sides lubed since the air flow might eventually dry out the oil.
